- Define the vendor option.
Perform this procedure to configure DHCP vendor option data global parameters.
The switch follows inheritance and precedence rules for configured DHCP Server options.
The switch process the DHCP options in the following order of precedence:
- host—Host configuration applies only to a specific host.
- DHCP subnet—DHCP subnet options apply to only those clients within the specified subnet.
- vendor class—Vendor class options apply to only those clients with a string that matches a specified vendor class identifier (VCI).
- global—Global options apply to all clients.
DHCP Server builds a cumulative configuration from all scopes but applies precedence rules in instances of conflict.
- Select DHCP Server.
- Select the Global Vendor option Data tab.
- Select Insert.
- In Id, type the DHCP code that you defined for the option.
- In Value, type the data value to assign to the option.
- Select Insert.
Global Vendor option Data Field Descriptions
Use the data in the following table to use the Global Vendor option Data tab.
Name | Description |
Id |
Specifies the DHCP code that identifies this vendor option. |
Value |
Specifies a value to apply to this vendor option. |
